[postgis-devel] malloc/palloc/lwalloc
Tom Lane tgl at sss.pgh.pa.us
Tue Sep 23 20:40:07 PDT 2008
"Paul Ramsey" <pramsey at cleverelephant.ca> writes:
> Makes sense. Grepping finds a few bare mallocs in there. Also lots of
> lwalloc lwfree in the lwgeom area. Does the idea of a bare malloc make
> any extra sense taken in combination with the fact that GEOS is going
> to be doing bare malloc all over the place anyways? Or
> memory-is-memory-is-memory?
Not familiar at all with the GEOS or Postgis code, just Postgres;
so take this advice for what its worth...
I think the $64 question is how your memory allocation and error
handling strategies interact.  If you have code that throws errors
using PG's elog() or ereport(), then you'd better be allocating memory
with palloc, because you won't get a chance to clean it up yourself.
Consider
	mymem = palloc(...);
	if (trouble)
		elog(ERROR, "trouble");
	pfree(mymem);
If the elog is reached then the pfree won't be, and so you need the
behind-the-scenes machinations of palloc/pfree to clean up.  If you
used plain malloc/free for mymem you'd have a memory leak here.
(Yeah, in this example you could put a free() just before the elog(),
but throw a few levels of subroutine calls into the example and it
gets unworkable PDQ.)
However, non-Postgres-oriented code like GEOS is most likely designed
to report errors via error return codes and to clean up its allocations
on the way out.  That works fine too, though it requires plenty of
attention to detail to ensure every failure path releases what it
should.
Where things fall down badly is where you mix the two styles.  In
particular, don't throw an elog/ereport from inside code called by
GEOS.
			regards, tom lane
