[postgis-devel] Issue 21 in postgis: locate_along_measure: wrong values, invalid data ?
codesite-noreply at google.com
Wed Sep 24 06:41:38 PDT 2008
Issue 21: locate_along_measure: wrong values, invalid data ?
http://code.google.com/p/postgis/issues/detail?id=21
Comment #9 by mark.cav... at siriusit.co.uk:
Thanks for the patch.
It looks like your solution and my solution are fairly similar, although my
approach
above involves removing the offending section of the code rather than
skipping it
with continue ;)
Does removing the section of code listed in comment 3 resolve the problem
aswell? If
so, I think that this is the preferred solution.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
