[postgis-devel] malloc/palloc/lwalloc
strk
strk at keybit.net
Wed Sep 24 14:37:45 PDT 2008
On Tue, Sep 23, 2008 at 11:28:34PM -0700, Paul Ramsey wrote:
> Tom,
> Since I have you here...
> I've been trying to track down memory leaks in PostGIS code, and the
> power of palloc is getting in my way... since palloc handles all the
> memory cleanly, valgrind thinks that the code is leakless, which it
> is, from a system point-of-view, but it also, clearly leaks.
> Ordinarily, this might be fine ("so what, it leaks, it'll get cleaned
> up in the end") but in our case, we are leaking so *much* memory that
> the database actually OOMs on some big workloads. Hence the leak hunt,
> but a difficult hunt, without supporting tools.
> Any ideas on tools / tricks?
Avoid postgres and use straight liblwgeom ?
--strk;
