[postgis-devel] ST_Contains(POLYGON, POINT) memory leak
Obe, Regina
robe.dnd at cityofboston.gov
Thu Sep 25 12:01:15 PDT 2008
Paul,
Yap p-i-p is in all those, but I think the commented out multi case is
in contains only.
On closer inspection of the code, I think the problem might be the
commented out code tries to use a
point_in_multipolygon(mpoly, point)
which hmm - maybe doesn't exist.
Anyrate - I think most of the complaints we get are of the pim case
rather than the pip case
so if we could speed that up, that would be a big and hopefully cheap
win.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Thursday, September 25, 2008 2:23 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] ST_Contains(POLYGON, POINT) memory leak
The p-i-p shortcut is in contains, intersects, within, covers,
coveredby, I believe. Once (if?) I've got the backend code memory
clean, I'll go through and see what I can do to clean up the calling
code and perhaps turn on MULTI.
P.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
