[postgis-devel] Issue 55 in postgis: Enchance P-I-P Shortcut
codesite-noreply at google.com
Fri Sep 26 11:26:43 PDT 2008
Issue 55: Enchance P-I-P Shortcut
http://code.google.com/p/postgis/issues/detail?id=55
New issue report by pwramsey3:
The P-I-P shortcut code builds a polygon index every time a new polygon
comes in, and should only do so the *second* time it sees a repeated
polygon, for the case where the polygons are not very static at all. (1:1
point-in-poly correspondence or less)
Issue attributes:
Status: Accepted
Owner: pwramsey3
Labels: Type-Enhancement Priority-Medium
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
