[postgis-devel] Issue 146 in postgis: 1.4 ST_Distance and ST_Dwithin doesn't behave like 1.3
codesite-noreply at google.com
Fri Apr 3 23:38:59 PDT 2009
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Priority-Critical Milestone-1.4
New issue 146 by robe.... at cityofboston.gov: 1.4 ST_Distance and ST_Dwithin
http://code.google.com/p/postgis/issues/detail?id=146
What steps will reproduce the problem?
1. Run the below
SELECT ST_Distance(g1,g2), ST_Dwithin(g1,g2,0.01), ST_AsEWKT(g2)
FROM (SELECT ST_geomFromEWKT('LINESTRING(1 2, 2 4)') As g1,
ST_Collect(ST_GeomFromEWKT('LINESTRING(0 0, -1 -1)'),
ST_GeomFromEWKT('MULTIPOINT(1 2,2 3)')) As g2)
As foo
What is the expected output? In 1.3.5 I get this
2.23606797749979;f;GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1
2,2 3))
What do you see instead? In 1.4 I get this
ERROR: Unsupported geometry type: MultiPoint
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
