[postgis-devel] Issue 146 in postgis: 1.4 ST_Distance and ST_Dwithin doesn't handle collections correctly
codesite-noreply at google.com
Sun Apr 5 09:48:44 PDT 2009
Updates:
Status: Testing
Comment #4 on issue 146 by pwramsey3: 1.4 ST_Distance and ST_Dwithin
http://code.google.com/p/postgis/issues/detail?id=146
Applied modified version to 1.3 branch at r3966, to trunk at r3967.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
