[postgis-devel] Issue 147 in postgis: regress_ogc_prep fails with PostgreSQL crash
codesite-noreply at google.com codesite-noreply at google.com
Wed Apr 8 02:56:59 PDT 2009
Comment #2 on issue 147 by mloskot: regress_ogc_prep fails with PostgreSQL
crash
http://code.google.com/p/postgis/issues/detail?id=147
I'm sorry, I've forgot to add this very important detail. I use SVN trunk:
mloskot at vb-ubuntu810-i386:~/dev/geos/_svn/trunk$ svn info | grep Revision
Revision: 2319
The last revision submitted yesterday (04/07/09).
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
