[postgis-devel] Issue 150 in postgis: Can not read shape file with windows newline
codesite-noreply at google.com
Wed Apr 22 07:26:02 PDT 2009
Status: New
Owner: ----
New issue 150 by stefangasser.info: Can not read shape file with windows
newline
http://code.google.com/p/postgis/issues/detail?id=150
What steps will reproduce the problem?
1. Import the attached Shape file with the command:
shp2pgsql -s 25832 -D -W 'UTF-8' PILLAR.shp skigis.pillar > shape.sql
2. When trying to import this into PostGIS with:
psql test < shape.sql
PostgreSQL complains with:
SET
BEGIN
NOTICE: CREATE TABLE will create implicit sequence "pillar_gid_seq" for
serial column "pillar.gid"
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"pillar_pkey" for table "pillar"
CREATE TABLE
addgeometrycolumn
skigis.pillar.the_geom SRID:25832 TYPE:POINT DIMS:2
(1 row)
ERROR: missing data for column "ist_name"
CONTEXT: COPY pillar, line 1: "16 Test Bug DE: Sostegno asimmetrico di
appoggio/ritenuta test"
ROLLBACK
This is probably caused by having a Windows style new line in the field
pil_text.
The shape file was generated by pgsql2shp from the table described in
pgbug.sql.
We are using PostGIS 1.3.5 on PostgreSQL 8.2.9 on CentOS 5.3 x86_64.
Please provide any additional information below.
SKIGIS_2009-04-22_PILLAR.shp.zip 771 bytes
shape.sql 884 bytes
pgbug.sql 4.0 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
