[postgis-devel] I presume this is just a me or a MingW problem?
Paul Ramsey
pramsey at opengeo.org
Mon Aug 3 09:16:09 PDT 2009
Werks fer mee. That kind of thing (compiles, ergo headers are there
and consistent) but doesn't link (ergo the libraries are missing the
symbols) usually indicates you're linking against something different
than what you compiled against. Make sure you blow away all the
libraries in install locations (/usr/local/lib, whatever) so that you
only have the new ones there.
P.
On Mon, Aug 3, 2009 at 8:07 AM, Obe, Regina<robe.dnd at cityofboston.gov> wrote:
> I was all excited when I finally got GEOS trunk to compile under MingW,
> but to my frustration, I get this
> lwgeom_geos.o:lwgeom_geos.c:(.text+0x3be9): undefined reference to
> `GEOSBufferWithStyle'
> lwgeom_geos.o:lwgeom_geos.c:(.text+0x4c65): undefined reference to
> `GEOSHausdorffDistanceDensify'
> lwgeom_geos.o:lwgeom_geos.c:(.text+0x4d65): undefined reference to
> `GEOSHausdorffDistance'
> collect2: ld returned 1 exit status
> I see those functions in the capi/geos_c.cpp and related in
> capi/geos_ts_c.cpp so I assumed they are in my compiled capi dlls.
> Even after blowing out my whole trunk and starting from scratch still
> have these errors. Is it just me suffering thru this? I have yet to
> try on my OpenSUSE installs.
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
