[postgis-devel] Typmod Enforcement
Kevin Neufeld
kneufeld at refractions.net
Mon Aug 3 14:06:27 PDT 2009
Personally, I agree with David for the exact reason he mentioned.
Avoid autoconversions / autocasting /
auto-what-just-happened-with-my-data? Be explicit, but provide
convenience functions for easy casting or conversions ... which we
already have (ST_Force_2D, ST_Force_3D, ST_Force_3DM,...)
So my two cents are to complain rather than insert (with warnings).
As for the parameter sequence, my vote is ( type, [srid] ) for the
reasons you outlined Paul.
-- Kevin
Paul Ramsey wrote:
> Having now figured out the magic of typmod enforcement, there's an
> interesting "extra feature" available that old fashioned constraint
> enforcement didn't provide: if we want we can coerce bad data into
> good data during the enforcement stage.
> Here's as example:
> If I have a column with type POINTZ and I feed it a POINT, there's not
> much I can do -- the input is lacking sufficient information. However,
> if I have a column with type POINT and feed it a POINTZ, I have the
> option of stripping the input down to the column dimensionality. The
> PgSQL code for things like varchar() tosses errors on overlong input,
> except when the spare stuff is white space, in which case it truncates.
> So, in that example, information would be discarded in the coercion
> which I probably couldn't convince you to do. But what about this?
> If I have a column with SRID = 4326 and try to insert an object with
> SRID = 26910. I can coerce it into the right SRID with no data loss.
> Do I insert or complain?
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
