[postgis-devel] [PostGIS] #228: postgis_restore.pl createdb parameters are used also for createlang -> crash
trac at osgeo.org
Mon Aug 3 23:50:11 PDT 2009
crash
Reporter: havatv | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4
Keywords: hard upgrade, postgis_restore.pl, parameters |
I have installed 1.4.0, and wanted to test a hard upgrade using
postgis_restore.pl, as described in the user manual
(http://postgis.refractions.net/documentation/manual-1.4/ch02.html#hard_upgrade
- 2.7.2 Hard upgrade).
The user manual says that postgis_restore.pl can take parameters and pass
them on to createdb. This works fine.
However, these parameters are also passed on to createlang, which is not
happy with the createdb specific options and therefore aborts, so
postgis_restore.pl is aborted as well.
With the example used in the documentation ({{{sh utils/postgis_restore.pl
postgis.sql newdb olddb.dump -E=UNICODE}}}), I get the following error
message (Norwegian translation: "ugyldig flagg": invalid flag):
createlang: ugyldig flagg -- E
Try "createlang --help" for more information.
Also: It could perhaps be useful to include info on upgrade in the
release notes, even if soft upgrade is recommended by default (there has
not been any mention of upgrading in the release notes since 1.1.6).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/228>
