[postgis-devel] [PostGIS] #231: New distance-calculations proposal
trac at osgeo.org
Tue Aug 4 08:55:56 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Old description:
> A hopefully more structured ticket than #137
> The patch attached includes:[[BR]]
> '''new functions:'''[[BR]]
> 1. st_shortestline[[BR]]
> 2. st_longestline[[BR]]
> 3. st_dfullywithin[[BR]]
> '''enhancements affecting st_distance, st_dwithin and the functions
> above:'''[[BR]]
> 1. a better handling of "holes" in polygons. [[BR]]
> 2. a sudden stop in iteration when the distance in st_dwithin is
> satisfied. Before it was checked for every subgeom.[[BR]]
> 3. a new way of calculating distances between lines and polygons that
> don't intersect.[[BR]]
> [[BR]]
> Probably the last one is the most important. On big geometries it makes a
> big difference.[[BR]]
> [[BR]]
> Beside the patch I have attached a document where I try to explain the
> idea behind the distance-calculation.[[BR]]
> [[BR]]
> /Nicklas
New description:
4. st_max_distance [[BR]] (this is really a fix to a long standing bug --
st_max_distance has existed since at least 1.2 but has never worked -
(older versions give Not yet implemented))
above:'''[[BR]]
[[BR]]
[[BR]]
[[BR]]
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/231#comment:3>
