[postgis-devel] trunk regress fails
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Aug 5 02:01:31 PDT 2009
Kevin Neufeld wrote:
> I don't think this is related to the path problem, but this also happens
> on the same box.
> This is error I get when trying to install postgis in a new install of
> 8.2.13
> postgis=# \i /var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3871:
> ERROR:  cannot cast type text to cstring
> LINE 4:   CAST('quad_segs='||CAST($3 AS text) as cstring))
> psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3881:
> ERROR:  current transaction is aborted, commands ignored until end of
> transaction block
> psql:/var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis.sql:3887:
> transaction block
> -- Kevin
Hmmmm looks like this was introduced by strk's new buffer code. If we
ask him nicely, will he fix it? ;)
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
