[postgis-devel] [PostGIS] #230: st_expand seems to affect the execution order wich affects st_dwithin
trac at osgeo.org
Wed Aug 5 06:55:43 PDT 2009
Reporter: nicklas | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: 1.4
Resolution: | Keywords: st_dwithin st_expand bbox
Comment (by robe):
Exactly observe ( that part is coming from ST_DWithin -- if you look at
the definition of ST_DWithin -- it has 2 expand calls - this is one of
them)
" Index Cond: (a.the_geom && st_expand(b.the_geom, 0::double
precision))"
" Filter: ((a.state)::text <> 'Hawaii'::text)
The join filter part has the portion of ST_DWithin that doesn't use an
index (see how the second expand that is pushed to index is missing)
" Join Filter: ((b.the_geom && st_expand(a.the_geom, 0::double
precision)) AND _st_dwithin(a.the_geom, b.the_geom, 0::double
precision))"
The planner has split the function into its constituent parts. So lesson
learned putting cost on transparent SQL functions that use others is not
effective.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/230#comment:10>
