[postgis-devel] [PostGIS] #232: Implementation of ST_AsBinary for RASTER type
trac at osgeo.org
Wed Aug 5 07:50:42 PDT 2009
Reporter: mloskot | Owner: mloskot
Type: enhancement | Status: assigned
Priority: high | Milestone:
Component: wktraster | Version: trunk
Resolution: | Keywords: st_asbinary,bytea
Old description:
> This is just a record of the plan I've made to start implementing
> ST_AsBinary function for [wiki:WKTRaster WKT Raster]. The function is
> listed in the [wiki:WKTRaster/PlanningAndFunding big plan].
> The first version of ST_AsBinary I'm going to implement will do nearly
> the same what ST_byte function does. It's prototype is:
> bytea ST_AsBinary(raster r1);
> At the moment, I don't aim to implement compression support, but later it
> can be extended to provide it:
> bytea ST_AsBinary(raster r1, text compression);
New description:
The first version of [ST_AsBinary I'm going to implement will do nearly
I haven't planned to handle endianness as PostGIS'
[http://postgis.refractions.net/documentation/manual-1.4/ST_AsBinary.html
ST_AsBinary] does. So, it is expected that WKB is returned with endianness
native to the machine running the PostgreSQL database - it can vary. Feel
free to share your suggestions of solutions fot this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/232#comment:3>
