[postgis-devel] Typmod Goodness
Paul Ramsey
pramsey at opengeo.org
Fri Aug 7 10:15:43 PDT 2009
Check this out, the final reward for typmod!
-- Availability: 1.5.0
CREATE OR REPLACE VIEW GEOGRAPHY_COLUMNS
AS
SELECT
''::text AS f_table_catalog,
n.nspname AS f_table_schema,
c.relname AS f_table_name,
a.attname AS f_geography_column,
geography_typmod_dims(a.atttypmod) AS coord_dimension,
geography_typmod_srid(a.atttypmod) AS srid,
geography_typmod_type(a.atttypmod) AS type
FROM pg_class c,
pg_attribute a,
pg_type t,
pg_namespace n
WHERE c.relkind IN('r','v')
AND t.typname = 'geography'
AND a.attisdropped = false
AND a.atttypid = t.oid
AND a.attrelid = c.oid
AND c.relnamespace = n.oid
AND n.nspname NOT ILIKE 'pg_temp%';
geography=# select * from geography_columns;
-[ RECORD 1 ]------+---------------
f_table_catalog |
f_table_schema | public
f_table_name | foo
f_geography_column | g
coord_dimension | 2
srid | 0
type | Geometry
-[ RECORD 2 ]------+---------------
f_table_catalog |
f_table_name | foo2
coord_dimension | 3
srid | 0
type | PointZ
-[ RECORD 3 ]------+---------------
f_table_catalog |
f_table_name | foo3
coord_dimension | 4
srid | 4326
type | MultiPolygonZM
-[ RECORD 4 ]------+---------------
f_table_catalog |
f_table_name | voo
coord_dimension | 4
srid | 4326
oh, yeah!!!
P
