[postgis-devel] Typmod Goodness
Paul Ramsey
pramsey at cleverelephant.ca
Fri Aug 7 11:19:44 PDT 2009
On Fri, Aug 7, 2009 at 11:13 AM, Kevin Neufeld<kneufeld at refractions.net> wrote:
> Paul Ramsey wrote:
>>> And, may I ask why you filtered out pg_temp tables? Why would you not
>>> what
>>> to list geography columns on any temporary tables you may have made?
>> I'll turn the question back to you, since I created the view by
>> copying populate_geometry_columns :)
> :) Ah. populate_geometry_columns repopulates geometry_columns from all
> geometry columns detected in the database. The pg_temp filter is used here
> for the main reason that without it, temporary tables from *all* users would
> be retrieved. It's not appropriate (or permissible) to access a temp table
> in another users' session ... so why even list them in the first place,
> right? Also, another albeit weak answer is that since it's a static table
> (not a view) listing a geometry column that will disappear in the very near
> future may not seem like a good thing to do.
> With the geography_columns view, you would need the pg_temp filter IF you
> don't have the additional filter of pg_table_is_visible(). But if you're
> only looking at tables in your search_path (which can't possible include
> temp tables of other users), then you would have the option to list temp
> tables that are, in fact, available to you.
> Anywho, it's just a thought for discussion. I don't know what the specs say
> about it.
The specs are silent. I've incorporated both your suggestions.
P
