[postgis-devel] Typmod Goodness
Paragon Corporation
lr at pcorp.us
Fri Aug 7 13:11:12 PDT 2009
Not so much that its sensitive -- but imagine the frustration of a user --
they see all these wonderful tables -- they go to query them only to be
slapped on the wrist with a
"Denied"
That's actually one of those things I liked about MySQL -- that you can only
see databases you have access to. In SQL Server for example if you are on a
shared box, you have to wade through thousands of databases you can't even
access. Why do they bother?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
Hodgson
Sent: Friday, August 07, 2009 4:03 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Typmod Goodness
I'm not sure if you need the view which is limited by the search path - but
I think limiting it to tables the user has access to makes sense.
On the other hand, is there actually any sensitive data visible in the
geo(metry|graphy)_columns table? Does it need to be limited at all?
Chris
Kevin Neufeld wrote:
> I'm not partial either way, but perhaps it might be an idea to follow
> Oracle's example:
> http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_obj
> relschema.htm#i1001937
> Have two views. One to list the geography_columns in the user's
> search_path, and one to list all geography_columns which the user has
> select access to.
> -- Kevin
> Stephen Frost wrote:
>> * Paragon Corporation (lr at pcorp.us) wrote:
>>> I disagree with the pg_table_is_visible = true addition (if it
>>> ensures only tables in your search path).
>> So do I. I equate 'geometry_columns' and 'geography_columns' to
>> 'pg_class', 'pg_tables', or 'information_schema.tables', none of
>> which have any such filter based on current search_path. That's
>> something implemented in the client, where necessary and appropriate.
>> Thanks,
>> Stephen
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
