[postgis-devel] Cubic splines in GML
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Aug 14 09:45:50 PDT 2009
Andrei Ionita wrote:
> Hi everyone,
> I am seeking help on understanding the concept that GML is defining for
> cubic splines. I am involved in writing an interpolation algorithm in
> the deegree software that returns points on a cubic spline.
> Firstly, I have been looking at the GML definition of cubic splines and
> wondering how to interpret it. There, a cubic spline consist of control
> points and starting and ending tangent vectors. It appears as the
> piecewise cubic polynomials (that are defined mathematically for a cubic
> spline) can be deduced from the two tangents, but how does one do that?
> Or is the target of the GML type not one of defining a rigorous math object?
See http://en.wikipedia.org/wiki/Bezier_splines for more information.
There are several variations on parametric cubic curves, but Bezier is
one of the most common formulations.
> Apart from that however, I would also like to ask if someone from
> PostGIS has stumbled upon a discrete algorithm for interpolating cubic
> splines, or at least can give me some literature references.
I'm fairly sure you should be able to either implement a simple
algorithm yourself, or locate a suitable library routine from the
reference above.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
