[postgis-devel] Strange result about spatial indexes?
Paul Ramsey
pramsey at opengeo.org
Fri Aug 14 12:20:00 PDT 2009
No surprise, any function that returns cheaply and immutably will
provide the same effect. The effect is so huge, that you can even get
faster results using expensive functions.
suelos=# select count(*) from suelos1 p1, suelos1 p2 where
(st_envelope(p1.geom) && p2.geom);
count
13808
(1 row)
Time: 92.989 ms
(st_setsrid(p1.geom,23030) && p2.geom);
count
13808
(1 row)
Time: 92.626 ms
(st_convexhull(p1.geom) && p2.geom); count
13808
(1 row)
Time: 237.928 ms
suelos=# select count(*) from suelos1 p1, suelos1 p2 where (p1.geom && p2.geom);
count
13808
(1 row)
Time: 478.765 ms
