[postgis-devel] [PostGIS] #241: ST_LineCrossingDirection Server Crash (Segfault)
PostGIS trac at osgeo.org
Wed Aug 19 05:48:55 PDT 2009
  Reporter:  batzee    |       Owner:  robe
      Type:  defect    |      Status:  assigned
  Priority:  critical  |   Milestone:  postgis 1.4.1
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  segfault
Changes (by robe):
  * owner:  pramsey => robe
  * status:  new => assigned
Comment:
 On closer inspection.  I think its how we are freeing constant geometries
 that is the problem. Only seems to happen if I introduce a constant.
 For example this crashes too.
 SELECT sum(ST_LineCrossingDirection(a.the_geom,
 ST_GeomFromText('LINESTRING(1 2,3 4)')))
 FROM ((SELECT ST_MakeLine(ST_Point(i,j),ST_Point(j,i))  As the_geom
                 FROM generate_series(-10,50,10) As i
                         CROSS JOIN generate_series(40,70, 15) As j
                         WHERE NOT(i = j)
                         ORDER BY i, i*j) ) As a
Ticket URL: <http://trac.osgeo.org/postgis/ticket/241#comment:5>
