[postgis-devel] problem with spatial_ref_sys.sql
Kevin Neufeld
kneufeld at refractions.net
Thu Aug 27 10:51:39 PDT 2009
It looks like your target database is not spatially enabled.
Can you verify "geometry_columns" and "spatial_ref_sys" exist in your target database?
IE. you should see something like this.
sudo -u postgres psql -d fixmystreet
fixmystreet=# \d
List of relations
Schema | Name | Type | Owner
public | geometry_columns | table | postgres
public | spatial_ref_sys | table | postgres
(2 rows)
To verify your libraries are properly working, try this:
fixmystreet=# SELECT ST_AsText('POINT(0 0)'::geometry);
st_astext
POINT(0 0)
(1 row)
-- Kevin
Zico wrote:
> On Thu, Aug 27, 2009 at 11:29 PM, Kevin Neufeld
> <kneufeld at refractions.net <mailto:kneufeld at refractions.net>> wrote:
> Scroll to the beginning of the log, before all the
> ERROR: current transaction is aborted, commands ignored until end
> of transaction block
> What's reason the block is aborted?
> /*debian:/usr/share# sudo -u postgres psql -d fixmystreet -f
> /usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql >
> /root/Desktop/check.txt
> sudo: unable to resolve host debian
> psql:/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql:5: ERROR:
> relation "spatial_ref_sys" does not exist
> psql:/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql:9: ERROR:
> current transaction is aborted, commands ignored until end of
> transaction block
> Best,
> Zico
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
