[postgis-devel] [PostGIS] #221: Upgrade performance tips in documentation
PostGIS trac at osgeo.org
Fri Aug 28 04:37:36 PDT 2009
  Reporter:  pramsey  |       Owner:  jlivni
      Type:  task     |      Status:  closed
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 committed at r4425.  Also took some artistic liberties by linking back to
 relevant sections of the PostgreSQL manual and other sources as well as
 items that are obsolete or have changed in later versions of PostgreSQL.
 Kevin can you correct if I got anything wrong with the WAL part.  That was
 the part I was most unsure about.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/221#comment:2>
