[postgis-devel] Problem with ~/postgresql-8.3-postgis/lwpostgis.sql
Zico
mailzico at gmail.com
Sun Aug 30 07:23:46 PDT 2009
On Sun, Aug 30, 2009 at 1:56 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Zico,
> This is a user question, you should be asking on the PostGIS Users group.
> Which version of PostGIS are you trying to install? 1.3 or 1.4
> In 1.4 the new file is just called postgis.sql (no longer lwpostgis.sql)
Yes, it is postgis.sql
> It could be that you are running the 1.3 file and have postgis-1.4
> .so/.dll loaded.
> Check line 6460 of your lwpostgis.sql file to see what that line says.
> Since that is where it is breaking.
Actually... this error is coming from various lines.. as for example:
*psql:/opt/postgis-1.4.0/postgis/postgis.sql:6665: ERROR: current
transaction is aborted, commands ignored until end of transaction block
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6703: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6752: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6775: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6781: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6805: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6816: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6821: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6826: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6944: ERROR: current
psql:/opt/postgis-1.4.0/postgis/postgis.sql:6949: ERROR: current
ROLLBACK
Here, i want to let you know that, i have changed the permission for that
directory too. I cannot understand what is going on there. :(
Best,
Zico
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090830/154c13cb/attachment.html>
