[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Tue Dec 1 10:46:51 PST 2009
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Mark,
Does this work for you? This is backtrace against a PostgreSQL 8.4.0 mingw
compiled
against r4962 trunk.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 4324.0x1464]
0x00000000 in ?? ()
(gdb) bt
#0 0x00000000 in ?? ()
#1 0x68f286fd in parse_gml_coordinates (xnode=0x41628e0, hasz=0x140f3df
at lwgeom_in_gml.c:623
#2 0x68f28f2e in parse_gml_data (xnode=0x41628e0, hasz=0x140f3df "",
root_srid=0x140f3d8) at lwgeom_in_gml.c:871
#3 0x68f291dd in parse_gml_point (xnode=0x4162740, hasz=0x140f3df "",
root_srid=0x140f3d8) at lwgeom_in_gml.c:934
#4 0x68f2ac5e in parse_gml (xnode=0x4162740, hasz=0x140f3df "",
root_srid=0x140f3d8) at lwgeom_in_gml.c:1544
#5 0x68f2778d in geom_from_gml (fcinfo=0x140f4a0) at lwgeom_in_gml.c:108
#6 0x0052df66 in ExecMakeFunctionResult (fcache=0x416dcc0,
econtext=0x416e108, isNull=0x140f737 "", isDone=0x0) at
execQual.c:1685
#7 0x0052e91c in ExecEvalFunc (fcache=0x416dcc0, econtext=0x416e108,
isNull=0x140f737 "", isDone=0x0) at execQual.c:2116
#8 0x005320f4 in ExecEvalExprSwitchContext (expression=0x416dcc0,
execQual.c:4095
#9 0x005afae2 in evaluate_expr (expr=0x416beb0, result_type=32796,
result_typmod=-1) at clauses.c:3842
#10 0x005af194 in evaluate_function (funcid=33359, result_type=32796,
result_typmod=-1, args=0x416be98, func_tuple=0x41364c0,
context=0x140f9d0)
at clauses.c:3449
#11 0x005aecf6 in simplify_function (funcid=33359, result_type=32796,
result_typmod=-1, args=0x140f830, allow_inline=1 '\001',
context=0x140f9d0) at clauses.c:3253
#12 0x005ad382 in eval_const_expressions_mutator (node=0x416bd70,
context=0x140f9d0) at clauses.c:2134
#13 0x0055ce3b in expression_tree_mutator (node=0x416bd98,
mutator=0x5ad1b5 <eval_const_expressions_mutator>, context=0x140f9d0)
at nodeFuncs.c:1898
#14 0x005ae8b7 in eval_const_expressions_mutator (node=0x416bd98,
context=0x140f9d0) at clauses.c:2951
#15 0x0055cf5a in expression_tree_mutator (node=0x415b6e8,
at nodeFuncs.c:1944
#16 0x005ae8b7 in eval_const_expressions_mutator (node=0x415b6e8,
#17 0x005ad174 in eval_const_expressions (root=0x415c798, node=0x415b6e8)
at clauses.c:2027
#18 0x0059d2c3 in preprocess_expression (root=0x415c798, expr=0x415b6e8,
kind=1) at planner.c:540
#19 0x0059cf89 in subquery_planner (glob=0x415b700, parse=0x415b610,
parent_root=0x0, hasRecursion=0 '\000', tuple_fraction=0,
subroot=0x140faac) at planner.c:375
#20 0x0059cb93 in standard_planner (parse=0x415b610, cursorOptions=0,
boundParams=0x0) at planner.c:190
#21 0x0059ca60 in planner (parse=0x415b610, cursorOptions=0,
boundParams=0x0)
at planner.c:122
#22 0x005fa88a in pg_plan_query (querytree=0x415b610, cursorOptions=0,
boundParams=0x0) at postgres.c:697
#23 0x005fa932 in pg_plan_queries (querytrees=0x416be20, cursorOptions=0,
boundParams=0x0) at postgres.c:756
#24 0x005fabca in exec_simple_query (
query_string=0x415b180 "\nSELECT
ST_GeomFromGML('<gml:Point><gml:coordinates
>1,2</gml:coordinates></gml:Point>')") at postgres.c:920
#25 0x005feb28 in PostgresMain (argc=4, argv=0x4085458,
username=0x234280 "postgres") at postgres.c:3614
#26 0x005c9d10 in BackendRun (port=0x140fdd0) at postmaster.c:3393
#27 0x005ca74c in SubPostmasterMain (argc=3, argv=0x232cc0)
at postmaster.c:3866
#28 0x0055934f in main (argc=3, argv=0x232cc0) at main.c:165
(gdb)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:28>
