[postgis-devel] [PostGIS] #332: WKT geometry tag match and mismatch
trac at osgeo.org
Wed Dec 2 09:06:59 PST 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: trunk
Keywords: |
Depending on the manner of geometry construction from Well-Known-Text
representation, WKT geometry tag is case sensitive or not (POLYGON vs
polygon).
Here are details:
* Construction using ST_GeomFromText is case-sensitive
test=# SELECT ST_GeomFromText('polygon((0 0,4 0,4 4,0 4,0 0))');
ERROR: Invalid OGC WKT (does not start with P,L,M,C or G)
* Construction using explicit cast to GEOMETRY is '''not''' case-
sensitive
test=# SELECT 'polygon((0 0,4 0,4 4,0 4,0 0))'::geometry;
geometry
010300000001000000050000000000000000000000000000000000000000000000000010400000000000000000000000000000104000000000000010400000000000000000000000000000104000000000000000000000000000000000
(1 row)
test=# SELECT ST_AsText('polygon((0 0,4 0,4 4,0 4,0 0))'::geometry);
st_astext
POLYGON((0 0,4 0,4 4,0 4,0 0))
(1 row)
Environment:
* OS: Windows
* PostgreSQL
test=# select version();
version
PostgreSQL 8.4.0, compiled by Visual C++ build 1400, 32-bit
(1 row)
* PostGIS installed from Regina's packages
test=# SELECT postgis_full_version();
POSTGIS="1.5.0SVN" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/332>
