[postgis-devel] [PostGIS] #333: VACUUM in spatial_ref_sys.sql throws error
PostGIS trac at osgeo.org
Thu Dec 3 12:08:26 PST 2009
 Reporter:  kneufeld  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 1.5.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 Loading the spatial_ref_sys.sql file manually in PgAdmin III throws the
 error:
 ERROR:  VACUUM cannot be executed from a function or multi-command string
 ********** Error **********
 SQL state: 25001
 I recommend the two offending lines (1719 and 15142)
 VACUUM ANALYZE spatial_ref_sys;
 be replaced with
 VACUUM is not needed anyway since no DELETEs or UPDATEs have taken place,
 only INSERTs - there's no need to reclaim space.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/333>
