[postgis-devel] [PostGIS] #331: Function matrix - show geometry, geography, curve, 3d and mm support for each function
trac at osgeo.org
Fri Dec 4 03:21:48 PST 2009
each function
Reporter: robe | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by mloskot):
I've got comment to [http://mateusz.loskot.net/?p=1588 my blog post] that
may be useful to solve the IE8 issue:
Berend writes:
''A short survey shows that only the “Arial Unicode MS” font includes
checkmark glyphs. Apparently Firefox has some kind of fallback mechanism
in case a certain glyph does not exist. Short story: Use “font-family:
Arial Unicode MS, sans-serif;” and you’ll be fine.''
Ticket URL: <http://trac.osgeo.org/postgis/ticket/331#comment:12>
