[postgis-devel] Versioning and History
Paragon Corporation
lr at pcorp.us
Fri Dec 4 12:49:00 PST 2009
> And a comment:
> Think *Views*! ... hiding this complexity in views will make your life
easier plus it will not need changes in clients. Clients connecting to a
PostgreSQL DB can use the tables like they normally do, and clients that
want to leverage the versioning aspect of it can use the versioning stored
procedures (i.e set_current_version('myversion')).
> My two cents,
> - Ragi
Just a note. Views are great, but to many applications they don't see
primary keys and when they don't sadly views appear as read-only even if you
make them updateable. Just something to consider, that they are sadly not
as transparent as they should be. Think geoserver for example.
Regina
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091204/56f0b67d/attachment.html>
