[postgis-devel] [PostGIS] #332: WKT geometry tag match and mismatch
trac at osgeo.org
Thu Dec 10 02:29:55 PST 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
I think that we should keep the check for the moment, since at the moment
the behaviour is very clear: if it works with GeomFromText() then it's
standards-compliant, if it doesn't then it's clearly flagged with
GeomFromEWKT().
Until we have a new standard to work to, I think changing this behaviour
will only cause confusion. IMO the problem here is that the OGC SFS/SQL-MM
specifications have lagged behind reality for years now (I suspect the 99-
prefix denotes 1999) and don't cover things like predicates in multiple
dimensions, EMPTY geometry semantics and geodetic systems. At least with
the EWKT/EWKB functions what we're saying is that this extended
functionality is ours, and so we have every right to change it as we need.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/332#comment:5>
