[postgis-devel] [PostGIS] #332: WKT geometry tag match and mismatch
trac at osgeo.org
Thu Dec 10 08:07:08 PST 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Yes I'm aware of what I'm signing on to. I think for this whole OGC
discussion -- its really more relevant what we do in output functions --
and for inputs that we accept at a minimum what the OGC/MM requires given
OGC/MM inputs.
If we loosen our constraint a little -- it doesn't change prior behavior
-- old apps work unchanged and behave exactly the same (except possibly
they won't be whining so when given extended input or binary -- does
anyone care? :)) . So new apps can get away with passing in 3D or SRID or
binary. I don't see that as big enough issue to complicate our code over.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/332#comment:9>
