[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Fri Dec 11 02:15:40 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Wow so I managed to get both of you on the windows bandwagon. This is
certainly more than what I could have hoped for.
FWIW -- this is the way I toggle back and forth between static compile and
link. Well seems to work for me anyway but all this stuff is still cryptic
to me.
My make check wa actually passing last time I tried except I think for one
small error.
cd /c/projects/libxml/libxml2-2.7.6
make uninstall
make clean
#to create linked
./configure --prefix=/c/projects/libxml/libxml2-2.7.6release --enable-
shared --disable-static
# to create static
./configure --prefix=/c/projects/libxml/libxml2-2.7.6release --disable-
shared CCFLAGS=LDFLAGS="-Wl,-static" CFLAGS=-O2
make && make install && make check
I haven't put it up yet since I assume we will want link dll which as Paul
said is what happened when I follow just standard build. Though I fear
this problem is more serious than just the way we are freeing memory in
windows.
I'll have to dig up the reports I have read about it - but as I recall
seemed to be a common issue with libxml in windows (though those reports
may be dated).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:34>
