[postgis-devel] Unable to compile with MinGW/MSYS - GEOS Problem
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Dec 11 08:24:34 PST 2009
Yes I did.
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>Sent: 11 décembre 2009 11:10
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] Unable to compile with MinGW/MSYS - GEOS Problem
>Following those instructions it "werks for me". Did you do the obscure
>edit to the MinGW header files described in the page?
>P
>On Fri, Dec 11, 2009 at 7:36 AM, Pierre Racine
><Pierre.Racine at sbf.ulaval.ca> wrote:
>> Hi,
>> I'm carefully following the instructions in:
>> http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile
>> trying to compile PostGIS 1.4.1 RC2 with PostgreSQL 8.4.1, but GEOS does not compile.
>> The first attempt with the geos-svn version ends with:
>> g++ -g -O2 -DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long -ffloat-store -o
>.libs/IteratedBufferStressTest.exe IteratedBufferStressTest.o ../../../..//source/.libs/libgeos.dll.a
>-L/c/postgres/lib
>> creating IteratedBufferStressTest.exe
>> .libs/lt-IteratedBufferStressTest.exe.c: In function `main':
>> .libs/lt-IteratedBufferStressTest.exe.c:79: warning: passing arg 2 of `execv' from incompatible
>pointer type
>> make[4]: Leaving directory `/c/thesrc/geos-svn/tests/perf/operation/buffer'
>> Another attempt using geos-3.2.0rc4 ends with:
>> g++ -DHAVE_CONFIG_H -I. -I../../../../source/headers -I../../../../source/headers/geos -
>I../../../../source/headers -I../../../../source/io/markup -g -O2 -DGEOS_INLINE -pedantic -Wall -
>ansi -Wno-long-long -ffloat-store -MT IteratedBufferStressTest.o -MD -MP -MF
>.deps/IteratedBufferStressTest.Tpo -c -o IteratedBufferStressTest.o IteratedBufferStressTest.cpp
>> mv -f .deps/IteratedBufferStressTest.Tpo .deps/IteratedBufferStressTest.Po
>> /bin/sh ../../../../libtool --tag=CXX --mode=link g++ -g -O2 -DGEOS_INLINE -pedantic -Wall -ansi
>-Wno-long-long -ffloat-store -o IteratedBufferStressTest.exe IteratedBufferStressTest.o
>../../../../source/libgeos.la ../../../../source/libgeos.la
>> libtool: link: g++ -g -O2 -DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long -ff
>> loat-store -o .libs/IteratedBufferStressTest.exe IteratedBufferStressTest.o
> ../../../../source/.libs/libgeos.dll.a -L/c/postgres/lib
>> ./.libs/lt-IteratedBufferStressTest.c:267: warning: string length `4299' is greater than the length
>`509' ISO C89 compilers are required to support
>> ./.libs/lt-IteratedBufferStressTest.c: In function `main':
>> ./.libs/lt-IteratedBufferStressTest.c:362: warning: implicit declaration of function `_spawnv'
>> ./.libs/lt-IteratedBufferStressTest.c:362: error: `_P_WAIT' undeclared (first use in this function)
>> ./.libs/lt-IteratedBufferStressTest.c:362: error: (Each undeclared identifier is reported only once
>> ./.libs/lt-IteratedBufferStressTest.c:362: error: for each function it appears in.)
>> c:\MinGW\bin\strip.exe: './IteratedBufferStressTest.exe': pas de fichier comme tel
>> ../../../../libtool: line 7842: 1: ambiguous redirect
>> What version should I use? How can I fix this?
>> Thanks for any hint.
>> Pierre
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
