[postgis-devel] [PostGIS] #347: Creating geography type is confusing
trac at osgeo.org
Tue Dec 15 06:38:39 PST 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Changes (by mcayland):
* milestone: PostGIS Future => PostGIS 1.5.0
Comment:
I think this was something I touched on before; i.e. a geography without a
SRID is useless compared to a geometry without a SRID :(
For example, for a geometry if we have a polygon we can still calculate
area + length (IMO two of the fundamental properties of a
linestring/polygon) regardless of whether or not we have a SRID. This
allows us to use many calculations SRID-less without much of an issue.
However, for geography the area + length calculations are both dependent
on the SRID which contains the required information for the curvature of
the sphere and so without a SRID we can't really do much at all.
My recommendation would be to currently enforce SRID 4326 on all new
geographies in trunk so then we always have a reference to calculate these
two properties. I also think this should be marked as for 1.5.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/347#comment:1>
