[postgis-devel] [PostGIS] #348: [wktraster] st_raster_envelope & st_raster_to_box2d return different results
PostGIS trac at osgeo.org
Wed Dec 16 02:32:33 PST 2009
results
  Reporter:  pracine    |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  high       |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by mloskot):
 The difference (WKT Raster Windows build by Regina from 2009-08-10
 17:41:12) is as follows:
  * SELECT ST_AsText(st_raster_envelope(rast)) FROM mytable
 POLYGON((-90 90,-72 90,-72 72,-90 72,-90 90))
  * SELECT ST_AsText(st_raster_to_box2d(rast)) FROM mytable
 POLYGON((-90 72,-90 90,-72 90,-72 72,-90 72))
 The two geometries are almost identical. The only difference is which is
 the first vertex, upper left vs lower left corner.
 What does the "should return two identical lines" mean? Which line is the
 one that should be returned?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/348#comment:1>
