[postgis-devel] [PostGIS] #297: [wktraster] Implement ST_AsPolygon function for raster
trac at osgeo.org
Mon Dec 21 14:11:34 PST 2009
Reporter: mloskot | Owner: jorgearevalo
Type: task | Status: assigned
Priority: high | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by pracine):
Replying to [comment:1 mloskot]:
> Pierre,
> Technically, we can use GDAL function, namely
[http://www.gdal.org/gdal__alg_8h.html GDALPolygonize].
> However, we have to keep in mind what steps it would require on various
levels of use and deployment. It is, roughly:
> * GDAL requirement, compile-time and run-time
> * Translation of WKT Raster WKB to
[http://www.gdal.org/classGDALDataset.html GDALDataset] with bands (likely
using GDAL MEM driver)
> * Call to GDALPolygonize to generate
[http://www.gdal.org/ogr/classOGRLayer.html OGRLayer]
> * Translation of [http://www.gdal.org/ogr/classOGRGeometry.html
OGRGeometry] objects attached to OGRLayer to PostGIS geometry
Sounds good!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/297#comment:8>
