[postgis-devel] [PostGIS] #355: Can't make shp2pgsql-gui a plugin anymore under PgAdmin III
trac at osgeo.org
Tue Dec 22 11:40:38 PST 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
For 1.5, I have added a 'shp2pgsql-pgadmin.exe' build target you can make,
which omits the -mwindows and icon resources. see if that makes things
work under PgAdmin. (I wonder if you'll get that ugly console thing --
probably. Seems a bad tradeoff. I wonder why the pgadmin plugin code
doesn't like the -mwindows version.)
For 1.4, the command-line addition hasn't been put in, that's why it's not
picking up the plug-in options.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/355#comment:1>
