[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
trac at osgeo.org
Wed Dec 23 17:50:31 PST 2009
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Just download the experimental and that's the way the structure is.
contrib/postgis (this is folder shared by all that contains proj)
contrib/postgis-1.4
contrib/postgis-1.5
Only difference, which I really regret not being more of a cowboy on is
the template database is still called template_postgis when I install
instead of being versioned (unlike what the experimental batch scripts
have)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:13>
