[postgis-devel] [PostGIS] #359: Issue with gui when loading some files
trac at osgeo.org
Sun Dec 27 09:41:03 PST 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version:
Resolution: | Keywords:
Comment (by mcayland):
I found some initialisation bugs in the GUI which are now fixed in SVN (at
least, it seems to work with the above file). Please can you test and try
again.
There does seem to be a problem with the length of a line in GTK though;
if you re-run the file but tick the "disable big integers" options it
seems that GTK crashes due to the long SQL lines. I'm wondering if perhaps
we should consider truncating them at 255 characters or so?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/359#comment:1>
