[postgis-devel] [PostGIS] #359: Issue with gui when loading some files
trac at osgeo.org
Mon Dec 28 05:36:33 PST 2009
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
I've just added an extra couple of missing defaults to SVN trunk
(basically any uninitialised values will just be set to random values on
startup). Please can yourself and Nicklas try again and see that this
solves everything for you? The only thing that is missing is to use a
shortened length for failed SQL statements, and perhaps change the default
to COPY rather than INSERT for the GUI (there is a section in main() where
the defaults can be overridden).
Tomorrow I'll be back at home and so will be able to spend a bit more time
looking at a sensible solution to #311.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/359#comment:6>
