[postgis-devel] Issue 111 in postgis: Enhancement request - Minimum Bounding Circle for PostGIS
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 2 15:34:10 PST 2009
Comment #1 on issue 111 by rind... at lrcwe.com: Enhancement request - Minimum
http://code.google.com/p/postgis/issues/detail?id=111
Revised function using ST_* functions
	MBC.txt  4.1 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
