[postgis-devel] WKT Parser changes for Curve support
Mark Leslie
mrk.leslie at gmail.com
Mon Feb 2 19:42:40 PST 2009
I've cobbled together a quick RFC describing some changes I'd like to
impose upon the parser in order to support the CompoundCurve and
CurvePolygon properly. I've committed it to trunk:
http://svn.refractions.net/postgis/trunk/doc/rfc/postgis_rfc_04.txt
The short summary is that our practise of using global variables to
define constraints such as minimum number of points or ring closure no
longer work once we start dealing with nesting of multiple geometry
types and constraints between sub-geometries, such as checking the
continuity of a compound curve.
My proposed change moves the validation to the level of a complete
geometry, instead of validating each point array on completion. The
down sides are that it will need to traverse the list of tuples to
properly validate which can only degrade performance, and it will no
longer report which point array is in violation of a given constraint,
only which geometry.
Please have a look at the rfc and share any comments you have.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
