[postgis-devel] Issue 110 in postgis: shp2pgsql new option to not batch commit
codesite-noreply at google.com
Wed Feb 4 04:45:10 PST 2009
Comment #4 on issue 110 by robe.... at cityofboston.gov: shp2pgsql new option
to not batch commit
http://code.google.com/p/postgis/issues/detail?id=110
Yes 2 if possible -- also have the option to NULL the geometry. I think
others have
asked for the ability to NULL.
Its a reality we get bad data and the last set I had to deal with was
intentionally
bad. They had used the same malformed geometry to represent the absense of
a
geometry -- presumably to satisfy ESRI shapefile that requires a geometry
for all
records.
After trying to salvage these things -- closing them and so forth -- to my
shock they
were all the same malformed creatures.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
