[postgis-devel] Issue 110 in postgis: shp2pgsql new option to not batch commit
codesite-noreply at google.com codesite-noreply at google.com
Wed Feb 4 09:20:01 PST 2009
Comment #8 on issue 110 by mark.cav... at siriusit.co.uk: shp2pgsql new option
to not batch commit
http://code.google.com/p/postgis/issues/detail?id=110
The validity check at the moment is currently only OGC validity (i.e.
closed rings,
correct number of points), not topological (IsValid) validity. There is
currently no
link between the new liblwgeom and GEOS.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
