[postgis-devel] Windows Build Instructions
Charlie Savage cfis at savagexi.com
Wed Feb 4 14:53:29 PST 2009
Hey Paul,
If there is anything I'm an expert at, its this.
> Well, I started with GEOS, thinking it was self-contained, no dependencies...
Actually, start with proj4 - that the easiest.  And then do postgresql.
  Then postgis.
Last, give geos a try.  It can be troublesome sometimes, and takes
*forever* to build.
> I got MinGW and MSYS. No problems there. From your earlier note on
> License it sounds like I should have skipped MinGW in favour of MSVC?
Either works.  If you need to debug, use MSVC.  If you just want to
build, MingW is fine (but painful to setup).
> > I wasted some time getting appropriate autobuild tools to bootstrap
> the svn version, which eventually worked, but I also got the rc2
> tarball, in both cases, after a clean ./configure, the compilation
> died on the first .cpp file, complaining about missing
> ::vsnprintf
> Sorry, I'm away from my VM right now, so I can't get the extract error
> string. I'll provide the full details when I'm back at the ranch.
Ah, that must be something new.  This is postgis or geos?
Charlie
Charlie Savage
http://cfis.savagexi.com
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090204/8927fca6/attachment.bin>
