[postgis-devel] Issue 116 in postgis: Hex string representing POLYGON EMPTY crashes postmaster
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 16 17:42:00 PST 2009
Updates:
	Status: Accepted
	Labels: Priority-Medium Milestone-1.3.X
Comment #1 on issue 116 by robe.... at cityofboston.gov: Hex string
http://code.google.com/p/postgis/issues/detail?id=116
Happens on my 1.3.5 install too.  Also happens on my 8.3 1.4 so still seems
to be an
issue.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
