[postgis-devel] Issue 118 in postgis: shp2pgsql fails with MapInfo created dbf
codesite-noreply at google.com
Tue Feb 17 12:02:21 PST 2009
Status: New
Owner: ----
New issue 118 by richard.greenwood: shp2pgsql fails with MapInfo created dbf
http://code.google.com/p/postgis/issues/detail?id=118
What steps will reproduce the problem?
1. shp2pgsql -n assessor.DBF test
Use attached assessor.DBF file, which was generated by MapInfo 8.0. ORG
created dbf files seem to work correctly.
What is the expected output? What do you see instead?
Only the CREATE TABLE statement is issued, but no INSERT INTO statements
are created.
What version of the product are you using? On what operating system?
Fails with 1.3.5, worked with 1.3.3 and prior. Tested only on Windows XP.
Please provide any additional information below.
assessor.DBF 1.2 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
