[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com
Sat Feb 21 16:12:46 PST 2009
Comment #1 on issue 119 by mgl.gis: ST_AsSVG crashed DB backend with large
geometries.
http://code.google.com/p/postgis/issues/detail?id=119
Sorry, forgot to mention, I'm using PostgreSQL 8.3.6 & PostGIS 1.3.5:
postgis_full_version
POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.1, 21 August 2008"
USE_STATS
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
