[postgis-devel] Issue 120 in postgis: parse_hex does not accept lowe-case A-F characters
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 23 06:20:53 PST 2009
Comment #1 on issue 120 by mloskot: parse_hex does not accept lowe-case A-F
characters
http://code.google.com/p/postgis/issues/detail?id=120
This issue leaked when I was working with WKTRaster which uses this
function.
Here is more on that: http://logs.qgis.org/postgis/%23postgis.2009-02-23.log
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
